to WoodenBoat.com or
Boatbuilding and Boating Resources
CAT 46 POWER / SAILER
The Catamaran ROBERTS CAT 46 was designed to be built using the fibreglass panel construction techniques. The method is very simple to use and perfect for the inexperienced builder. All of the developing is done in the computer and patterns are supplied for the female frame formers. Special pre-scaled drawings are supplied for each hull panel making it simple for the builder to laminate all of the hull and superstructure on a flat table. The panels are set inside the pre-erected framework and laminated together similar to the plywood Stitch and Glue method.
www.bruceroberts.com/public/HTML/descriptions/cat46_description.htm
DESIGN SPECS
BRUCE ROBERTS-GOODSON
Year of Design:
LOA:
14.30 m 48' 8"
Beam Length:
7.25 m 23' 6"
Draft Length:
1.07 m 3' 6"
Displacement:
Materials:
Fiberglass
Propulsion:
200 to 200 hp
Skill Level to Build:
Cost:
$995
Website:
Contact Information:
1352 WALNUT AVE
ANNAPOLIS MD 21403
Phone: 1-410 279 2525
<< VIEW ALL BOAT PLANS & KITS
