Boat Plans & Kits Categories
- Canoes
- Kayaks
- Tenders & Prams
- Rowing Craft
- Daysailers
- Sailboats – Cruising
- Sailboats – Racing
- Sailboats – One-design
- Sailboats – Other
- Multihulls, Power & Sail
- Cabin Cruisers
- Power Outboard Boats
- Power Boats – Fishing
- Power Boats – Offshore
- Open Boats, Center Consoles
- Runabouts, Pontoon Boats, Deck Boats
- Trawlers
- Ribs – Inflatables
- Cradle Boats
SIGN UP FOR NEWS
You are here
CAT PS 36/39/470 POWER SAILER
CAT POWER SAILERS ( PS ) A CAT Power Sailer is a power cat capable of 12 to 30 knots under power and 12 to 18 knots under sail. These catamarans were designed to be built using the fibreglass panel construction techniques. The method is very simple to use and perfect for the inexperienced builder. All of the developing is done in the computer and patterns are supplied for the female frame formers. Special pre-scaled drawings are supplied for each hull panel making it simple for the builder to laminate all of the hull and superstructure on a flat table. The panels are set inside the pre-erected framework and laminated together similar to the plywood Stitch and Glue method. This is a POWER-SAILER CAT .. the bias is about 60% power and 40% sail.
DESIGN SPECS
| Designer: | BRUCE ROBERTS-GOODSON |
| Year of Design: | |
| LOA: | 10.83 m 35’-6” |
| Beam Length: | 5.18 m 17'-0" |
| Draft Length: | 0.550 m |
| Displacement: | |
| Materials: | Wood Fiberglass Metal |
| Propulsion: | 125 - 205hp. |
| Skill Level to Build: | AVERAGE SKILLS. |
| Cost: | $995 |
| Website: | |
| Contact Information: | 1352 WALNUT AVE ANNAPOLIS MD 21403 |
