Boat Plans & Kits Categories
- Canoes
- Kayaks
- Tenders & Prams
- Rowing Craft
- Daysailers
- Sailboats – Cruising
- Sailboats – Racing
- Sailboats – One-design
- Sailboats – Other
- Multihulls, Power & Sail
- Cabin Cruisers
- Power Outboard Boats
- Power Boats – Fishing
- Power Boats – Offshore
- Open Boats, Center Consoles
- Runabouts, Pontoon Boats, Deck Boats
- Trawlers
- Ribs – Inflatables
- Cradle Boats
SIGN UP FOR NEWS
You are here
Sabor, RYD-14.6
RYD-14.6 is intended to bring performance to back yard builders. Her flanks and bottom can be managed from a few pieces of plywood, no scarfs or scabbing little bits on to make up the length. Her rig can be custom as drawn or she could wear a number of modern production boat rigs, in her size range, such as the 420 or Jet 14. As drawn, her performance level will be much like a Wind Mill, though she looks a whole lot better. With more area rigs, she'll really fly. RYD-14.6 fine entry, V hull form will permit full plane in 8 knots of wind and the narrow beam insures you don't have much to hold you back. The cockpit is self draining, missing the transom, the appendages well shaped and her floatation chambers are designed for hiked out seating. A dozen sheets of plywood and some epoxy is all it takes to get her built.
DESIGN SPECS
| Designer: | Paul "PAR" Riccelli |
| Year of Design: | 2008 |
| LOA: | 15' 6" |
| Beam Length: | 4' 2" |
| Draft Length: | not much |
| Displacement: | 255 lbs. at 4" |
| Materials: | Wood Fiberglass |
| Propulsion: | |
| Skill Level to Build: | Handy novice |
| Cost: | $20 study plans $15 for download, full set $80 |
| Website: | |
| Contact Information: | 34539 Marshall Road Eustis FL 32736 |
Comments
info
Hello,
Thanks for the information you send us, and I congratulate you for your site. I'm amateur with boat building, but I am very passionate about boats and the sea. I like the idea to build one himself and being that I am amateur in construction have chosen a model Sabor, RYD-14.6 appears suitable as a beginner. Would like to ask you to help me with any more picture about this boat, how much of the entire construction plan and method of payment. Thank you very much and look forward to your reply. Best regards.
I suggest contacting the
I suggest contacting the designer directly. He doesn’t seem to have a website but his address and phone are above.
