to WoodenBoat.com or
Boatbuilding and Boating Resources
Power Outboard Boats
14' 6" Outboard Skiff,  LITTLE MOBY profile
A V-bottomed plywood skiff designed for rough water - a good fishing boat.
Construction: Plywood planking over sawn frames.
No lofting required.
Plans include 5 sheets.
18' Plywood Runabout, DOWNEASTER profile
A deep-V bottomed, open runabout built of plywood over sawn frames.
Lofting is required.
Jericho Bay Lobster Skiff profile
Designed by Joel White, the original boat was built plank-on-frame by Jimmy Steele (of Peapod fame), but no plans were ever drawn-until now.
21' Pretty Marsh Runabout profile
21′ 2″ Inboard/outboard runabout, built of marine plywood.
Several design options include center console, outboard as well as inboard/outboard.
And, configurations also include different heights for the windshield.
Albury Runabout profile
Built by eye in the Bahamas for the last 40 years, Doug Hylan’s drawings allow for strip-planking or cold-molding.
Construction: Strip-planked over laminated frames.
Alternative construction: Cold-molded, plans included.
Riva drawing
At 14 feet this is Riva’s only outboard powered design. Originally designed in the 1950s, only some 150 were ever produced. A very rare outboard with limited images of original examples anywhere.
Peeler Skiff at work
Designed by John C. Harris, this light but sturdy fishing and utility skiff—a “crab skiff,” as they’re known on the Chesapeake Bay—has been dubbed the “Peeler” after the Chesapeake slang for a local delicacy, soft-shell crabs.
Dillon Mini Vee racing in Pine City, MN
The Mini Vee is a simple-to-build v-bottom racing boat designed for APBA Mini GT and GT Pro racing. Also an excellent high-performance boat for the non-racer and a great boat building project for an individual or the whole family.
Dillon Pro Tunnel
The Pro Tunnel is an outboard racing tunnelboat designed for APBA class GT Pro, but also makes an excellent small high-performance boat for the non-racer, and a great individual or family building project.
LYS stands for Lumber Yard Skiff. These rugged flat bottom work skiffs were originally designed to be built using materials readily found in most lumber yards- underlayment plywood and spruce framing.
Pelicano Shrimper
The drawing board of Sam Devlin has created another winner. The Pelicano Shrimper is an excellent choice for anyone who wants to maximize practicality in an 18' 4" package.
Delta 500
Planing vee hull.
6 persons capacity
600kg/1300lbs
Flat Pack View 1
An easy-to-build boat designed to ship as a kit in a flat pack box. Everything needed to complete the boat, except the motor, is included in the kit.
views
Ski race/ Offshore power boat
VILA 570
VILA 570 is the smallest of a family of three small planing cruisers boats ranging from 19’ to 22’.
SILVER 55
The classical hull shape of old wooden runabouts of the 70’s combines perfectly well with the use of marine plywood. This allows SILVER 55 to be in the same time elegant and simple to build.
SCHIZZO
SCHIZZO is a simple, essential, versatil motorboat, suitable for novice boatbuilders.
SILVER 45
SILVER 45 is a very classical small runabout capable of planing at full charge with a 25 to 40 HP outboard engine.
SILVER 333
SILVER 333 is a very small classical runabout for one or two people which may easily be transported on top of a mid-size car roof.
Berry Point 26
The Berry Point 26 was designed to fulfill a need for a traditionally stylish, trailerable, moderately fast, and capable family cruiser. She had to be shallow draft, economical to operate and simple.
Pages
Subscribe to RSS - Power Outboard Boats
