Sailboats - Cruising
ROBERTS 19
Roberts 19 Trailerable gunkholing and coastal cruiser. Plans and full size frame patterns available for wood epoxy construction.
An oceangoing auxiliary cruiser featuring stout but simple carvel construction.
Lofting is required
Plans include 5 sheets.
Designed as a cat schooner; both sails have big round poles at their leading edges. Considering the performance potential of this hull, this rig is appropriate. The stayless rig is clean and will be cheap to build with solid fir poles.
SPRITZ, an essential and simple boat, has been studied and designed to be the ideal boat for novices in boatbuilding or in sailing.
Lion 550 Adrenaline, light boat, trailer envelope can significantly expand the geography of travel and take the owners a lot of positive emotions and adrenaline.
Resembling her 8′ cousin more than the sleeker 12′ Acorn, this chunky dinghy will be a good load carrier for her length—and she looks very, very British.Oughtred saves you from guess work by showing precisely how her planking should be lined off.Construction: Glued lapstrake plywood.Alternative c
Wynfall is a small but capable cruising boat -- although only 26' long, she has a waterline of almost 24', and displaces 9500 lbs.
Lion 870 comfortable yacht composite structures is a continuation of a series of yachts developed by the company Unik Yachts.
Keel/centerboard cutter designed by Edward Burgess in 1888 and first of his “Compromise 40-footers”.The plans produce a model that is 25″ long.You’ll receive 4 pages of plans historical information about the boat and step-by-step instructions for half-hull building,using the lift method.There are
A classic boat built by the East End Classic Boat Society in Amagansett, NY in 2014.
SOLD APRIL 2026 - NO MORE INQUIRIES
