Sailboats - Cruising
Cape Henry 21
Cape Henry 21 lapstrake plywood trailer sailer
If we have to base ourselves on market demand before 2008, the two daysailers that we propose are very small. At that time, generally characterized by a continuous increase in boat size, it seemed as though a daysailer could not be less than 12 m, (even better if it exceeded 15 m).
Comfortable round-bottomed ocean cruiser with carvel-planking and accommodations for two.
Lofting is required.
Plans include 9 sheets.
Late 19th-century skimming-dish sloop designed by Isaac P.
Construction: Carvel planked over sawn & steamed frames. Alternative construction: Cold-molded or strip. Lofting is required. Plans include 11 sheets.
ROBERTS SPRAY 27 TRAILERABLE CRUISER You can build this boat in wood epoxy and other materials too.
The FireBug is a small sailboat or yacht that you can amateur build at home, sailing club or school, then learn to sail. It's easy to sail and will be the fastest boat on the bay. Low cost too!
SF Pelican 12 foot: Three sheets of drawings, step-by-step building instructions, sail plans, lists for materials and hardware, and sailing handling information.
Note: Drawing plans come in pdf format and can be printed to full hard copy format.
My client wanted to circumnavigate, Cape Horn and all! He wished to build the boat himself and had limited skills in boatbuilding, limits on his budget, and a space about the size of a double garage.
