Sailboats - Cruising
ROBERTS 470
ROBERTS 470 - WOOD EPOXY
The accommodation of this design has been laid out to suit two couples. The Roberts 470 makes a fine long distance cruising yacht.
My client wanted to circumnavigate, Cape Horn and all! He wished to build the boat himself and had limited skills in boatbuilding, limits on his budget, and a space about the size of a double garage.
With an overall length of 27 feet this lovely cruiser accommodates up to four passengers comfortably. Room in the head for bunks and a working galley. Great live in boat as well as a weekend cruiser depending on your own personal adventure needs!
ROBERTS SPRAY 27 TRAILERABLE CRUISER You can build this boat in wood epoxy and other materials too.
Shallow-drafted V-bottomed cruiser with cross-planked bottom & berths for three. Construction: Carvel planked sides over sawn frames; cross planked bottom. Alternative: Strip-planked topsides. Lofting is required. Plans include 7 sheets.
Auxiliary cruising sloop evolving from the Hudson River and Friendship sloops.
Excellent for single handling with 450 sq. ft. of working sails, open decks and large cockpit.
Cutter designed by Edward Burgess in 1887, and the inspiration for the 40′ class.The plans produce a model that is 22″ long.You’ll receive 3 pages of plans, historical information about the boat, step-by-step instructions and full-sized patterns for each lift, as well as template for you to shape
A new M80 has been launched in NL.
This tri was built by the ultimate wooden boat builder, Eef, a legend now 81 years has built several wooden multihulls is very happy with his new creation.
For more information on the M90, the M80 and M60 visit:
Based loosely on the Folkboat, this plywood lapstrake double-ender combines comforting rough-water ability, and good looks.
Construction: Lapstrake plywood over laminated frames.
Alternative construction: Traditional plank on frame, strip or cold-molded.
This is a centerboard cruising boat for couples and small families. Lightweight and strong, it can be easily hauled with a trailer. Construction: Plywood topsides over bulkheads and stringers; strip planked bottom Lofting is required. Plans include 6 sheets.
Freelance: a geilow design, built by New York yacht and engine company in 1935, fully restored an
Full restoration completed 2024. Health issues force sale at reduced price. Bronze fastened.
