On the Newstand and Digital Library Now — January/February 2026, Issue No. 308 Preview
Plans & Kits
Search Plans & Kits
163 Results
Sailboats - Cruising
29' Gartside Cutter
Displacing more than 18,000 lbs, this is a big 29′ boat. She has a set of lines you can fall in love with. Construction: Carvel-planked over laminated frames. Alternative construction: Cold-molded or strip. Lofting is required. Plans include 5 sheets.
12' 10" Pooduck Skiff
This dinghy could be considered a big little boat.
She has a lot of excellent qualities: excellent rowing and sailing ability, easy construction, and mannerly towing habits.
Construction: Glued-lapstrake plywood.
Alternative Construction: Traditional lapstrake.
Raven Lady
Designed as a cat schooner; both sails have big round poles at their leading edges. Considering the performance potential of this hull, this rig is appropriate. The stayless rig is clean and will be cheap to build with solid fir poles.
SCHEGGIA
SCHEGGIA (designed to compete in 10 Foot Class – www.diecipiedi.it) is narrow at waterline which makes it fast. Thanks to its flare sides stability increases considerably when the boat starts to hee
BRANDO Footy Plans
The “Footy” class, for boats which fit within a 12″ x 6″ box.We think you’ll find this design completely irresistable.Designed by Flavio Faloci a naval architect based in Genova, Italy, BRANDO includes 12 pages of plans, detailed building instructions, and complies with Footy class rules for radi
26' Gaff Sloop
Shallow-draft, V-bottomed pocket cruiser with spartan accommodations for two.
Construction: Carvel planked over sawn frames
Alternative construction: Strip or plywood
POLLY
POLLY, designed to compete in Diecipiedi (10 Foot) Class (www.diecipiedi.it) is rather large and stable. Quite comfortable for its size it may be used also for sailing excursions.
Simplicity 35
A 35' centerboard cruising boat designed for long-distance cruising and living aboard. Simplicity’s raised deck and 11’ beam result in a spacious interior, with standing headroom throughout. Construction is plywood over plywood bulkheads and frames.
Lion 550 Adrenaline
Lion 550 Adrenaline, light boat, trailer envelope can significantly expand the geography of travel and take the owners a lot of positive emotions and adrenaline.
Pagination
51' 1956 Vic Franck Built Custom Ben Seaborn Sloop - Sea Fever
“Sea Fever” is a true classic designed by Ben Seaborn and built by Vic Franck in 1956.
CHIEF UNCAS
The CHIEF UNCAS is a classic, electric-powered boat built by the Electric Launch Company (ELCO) i
