Plans & Kits
Search Plans & Kits
163 Results
Sailboats - Cruising
Swaggie
Small blue water cruiser with Junk rig, inside steering station, and accommodation for up to four persons.
Suitable for home boatbuilders, all wood construction, lead ballast cast in small pigs.
Garvey 33
LOA: 33′ 1″LBP: 32′10″LWL: 26′ 8″BEAM: 10′ 0″DRAFT: 2′ 3½″/5′ 3½″DISPLACEMENT: 9,000lbs (approx)BALLAST: 2,000lbs lead under the settees.1,000lbs additional lead for trim.SAIL AREA: 388 sq.
Williams 24' Gaff Yawl
A simple, spacious, singlehanded cruiser designed for carvel construction. Construction: Carvel planked over steamed frames. Alternative construction: Cold-molded or strip. Lofting is required. Plans include 7 sheets
15' 8 OUGHTRED Stickleback Dory (Amberjack)
Good dories have a reputation for being difficult to design but easy to build. Iain Oughtred has taken care of the hard work here-you can’t go wrong with his detailed plans for this lapstrake (plywood) Swampscott derivative.Construction: Glued lapstrake plywood over sawn frames.Alternative constr
Young Baggie
YOUNG BAGGIE, with a hull length of 4 m, is the medium size of the three boats we designed drawing inspiration from the traditional sandbaggers.
Sea Bright 36
SEA BRIGHT 36L.B.P.: 36′BEAM: 10′ 11″DRAFT: 1′ 8″/4′ 7″DISPLACEMENT: 9,500 lbsBALLAST: 3,483 lbs, 2,000 lbs lead foil laminated in keel; 250 lbs trim; 633 lbs water; 600 lbs fuelWATER: 75 gallonsFUEL: 80 gallonsRIG: Gaff-rigged Cat SchoonerTYPE: New Jersey Sea Bright Skiff.
SPRITZ
SPRITZ, an essential and simple boat, has been studied and designed to be the ideal boat for novices in boatbuilding or in sailing.
PUCK 550
The PUCK reflects the spirit of the original class which was to create a boat used in regattas but also suitable for coastal cruising, easy to carry and inexpensive.
37' 3" Yawl, Controversy 36
Designed for strip-planking, the Controversy 36 features light displacement and good headroom, with light and open space throughout.
Construction: Strip-planked over bulkheads and frames
Plans include 16 sheets.
Pagination
20' Surf Dory with Electric Motor and Trailer
